Do they make a body mount system I can install on my Granite Mega 4x4 so I don't have to put these clips in everytime and can just screw on a cap. I put them on my sons slash and it seems a lot easier.
Thanks
Rick
Thanks
Rick
I will try that tomorrow. Tonight one got under my nail and it hurt! ThanksBody clips are a lot easier if you spread them out a little. They go on and off super easy after that.
Seems like I saw that somebody used the proline screw on caps on Arrma posts. You'd have to drill out the top of each post and get the set screw in place.I will try that tomorrow. Tonight one got under my nail and it hurt! Thanks
I use these on my Kraton Ruckus and Torment, you have to cut the nubs off the top of the body mounts and drill holes to use them, I'll snap some pictures when I get home if I remember. Someone bump this at about 6pm mountain standard time.Seems like I saw that somebody used the proline screw on caps on Arrma posts. You'd have to drill out the top of each post and get the set screw in place.
https://www.prolineracing.com/performance-parts/pro-line-body-mount-thumbwasher-kit.asp
Seems like printed ones could offer more color and design possibilities too.I use these on my Kraton Ruckus and Torment, you have to cut the nubs off the top of the body mounts and drill holes to use them, I'll snap some pictures when I get home if I remember. Someone bump this at about 6pm mountain standard time.
Alternatively if you have a dremel and some M4 screws you can use these too https://www.ebay.com/itm/362631137292 I ordered a 24 pack and the guy sent me 28 of them. I bought these last November and so far I have had the insert pull out of 1 of them.
Yeah except he only makes black ones.....Seems like printed ones could offer more color and design possibilities too.
Pics or it can’t happen ???Yeah except he only makes black ones.....
Maybe we could get @jondilly1974 or one of the other guys with 3d printers to jump on this. I have some spare ones still that I could send out so you guys can reverse engineer them.
Pics of what?Pics or it can’t happen ???
I guess he means pictures of the needed part (& the needed measurements).Pics of what?
I would go longer than that, the biggest complaint I see about the proline ones is that the set screws are too short and pull out. I'm almost positive I used 18mm screws.
What you want printed? Is it just the nuts?Pics of what?
I didn't want them printed was just saying that I'm sure one of you guys could probably make them and in different colors, you just so happened to be the only one who I could think of off the top of my head.What you want printed? Is it just the nuts?
Deez nutzWhat you want printed? Is it just the nuts?
