Virginia mud
Is there an alternative to body pins clips? I like the way traxxas body clips are. What are some ideas?
Good idea the body clips I will admit give me issues sometimes.I use these. Cut the body mount flush with the body perch drill a 3.5mm hole in the middle then thread the grub screws in. https://www.prolineracing.com/performance-parts/pro-line-body-mount-thumbwasher-kit.asp
Same. I like these better and they hold up to a good bashing too!I use these. Cut the body mount flush with the body perch drill a 3.5mm hole in the middle then thread the grub screws in. https://www.prolineracing.com/performance-parts/pro-line-body-mount-thumbwasher-kit.asp
