My TRX-4 has a few miles and scratches on it, so I decided to try a thing.
I was at the track with my Nephew and someone showed us how to remove scuff marks from an RC using some head light restoring wax. It's a bit gritty, you put it on your clothe and rub the marks and it disappears like magic. So I picked up some
Meguiars plastx to see if I can clean up my TRX-4 Body. I hit with some wet sanding with 400 and 600 grit sand paper, then used the Megquires Pastix
It's a little bit less shine, but there are a lot less scratched. My thought is I need to probably need some much finer grit sand paper 1200-2000 then use the Meguire's to polish it up.
Not sure I will get the deep scratches but there is no reason it can't shine again.
