Vorteks Boost metal slipper upgrade
mercer1987
I’m currently in the process of upgrading my boost to a 3s system, Ive got the steel slipper 3s assembly but I’ve ran into a few problems, I’ve put the bearings into the new metal mount power unit but when I close it all up there is some back and forth play on the spur , I’m not sure if this is right or if it’s supposed to be solid?
Also on the old boost slipper there was a red section with a spring and a nut that the center driveshaft slides onto once assembled, but the new steel slipper hasnt got this and instead both sides have female ends and I can’t see any way of attached the red section to the new slipper, I may be being a complete noob here but any help would be appreciated
I believe there needs to be 4 slipper plates for the metal spur.
How many did you install?
I bought the ready assembled unit
From what I can see searching YouTube I think I need this part, the one that came from the boost assembly was twice as long and went through the whole unit and had a spring and a nut on one end
Once you click the motor module in it won’t move back-and-forth. You need this to connect the drive shaft to the spur hub…
ARRMA Slipper Shaft, Red: BLX 3S, ARAC9102 https://a.co/d/236dnRt
