Cryogenius
I find the charger and even the battery checker all give somewhat inconsistent results in terms of IR and even just cell voltage
Check the voltage on three different device's, why is it different?
Which mode are you using to charge? It looks like you are using charge (CHG) mode instead of balance (BAL) mode. The manual for that charger says that CHG mode is for charging without the balance leads. Meaning it will charge but won't balance the cells even if you have the balance lead attached. Looks like you need to use BAL mode.Hi guys.
How can a brand new battery this unbalanced? This is its first charge? It didn't even get to 16.8v? Charged at 5A took 75mins
Absima Power Tank Lipo 14.8V.-60C 6200 Hardcase (XT90-Plug)
What you guys reckon?
Agreed. Reading voltage down to only a millivolt (or only 0.02 volts) is not that great. Most cheap multimeters read down to the thousandth volt. So that might be contributing to the issue here. However, even if calibrated off, the charger should charge until it thinks cells are balanced--if it's running in a balance charge mode. My suspicion is that this was regular "charge" mode.Just my two cents - these aren't really devices designed for accurate and precise bench measurements. I'm sure whatever spec there is (if there even is one) is pretty loose. Depending on which method they use to measure IR. a load/resistor has tolerance and I'm sure they're not spec'ing components with tight tolerances. Even good bench equipment needs to go through testing/cal on a regular basis to ensure that it delivers accurate results.
Yeah most 2 line display chargers have Time-Out setting you can change.This looks like a clone of my oldest charger. Good but slow.
Good news all is well.
Reality check. This is a 50W charger and will top out at 3A (power divided by volt 50/16)
That is 0.5C, charge time is normal at that level.
You have to use the Balance mode to charge, this will further extend your time. Below 2h is nominal in this setup and that is your normal.
You can set the charger to any higher current level but it will top out at its power limit.
I still use this for small lipos, if you want shorter durations you need a better charger. 100W minimum for your specific application.
I believe this charger also has a timeout setting, make sure it's above 2h.
I missed it in my first once through of the manual... why do they even have "CHARGE" as an option under lipo?Which mode are you using to charge? It looks like you are using charge (CHG) mode instead of balance (BAL) mode. The manual for that charger says that CHG mode is for charging without the balance leads. Meaning it will charge but won't balance the cells even if you have the balance lead attached. Looks like you need to use BAL mode.
Older 2 line display chargers had Charge and Balance Charge, because with Early RC Lipo introduction/adoption, Lipo packs did not come with Balance leads.I missed it in my first once through of the manual... why do they even have "CHARGE" as an option under lipo?
First couple of lines on page 16, then the rest of the page is telling you about balance charge.
https://guidessimo.com/document/956244/core-rc-uac-50-instruction-manual-28.html
