Motozilla
K 4S Internal Gear Ratio = 2.85 -- so 2.85 * 57T stock spur / 20t pinion = 8.12 Final Drive Ratio
K 6S Internal Gear Ratio = 4.3 -- so 4.3 * 50T stock spur / 20t pinion = 10.75 Final Drive Ratio
You'll need to put a 15T pinion on your Kraton 4S to make it a 1:1 comparison to your Kraton 6S.
EDIT: Although, tire diameter and weight come into play, and i'm guessing you have larger diameter tires on your 6S -- so maybe not all the way down to 15T... Hard to calculate exactly because of ballooning.
Edit Edit: Sorry, Yonic already did the math here ... what i get for posting without refreshing first!
