sroy
Brand new 6S Roller fully built. There isn’t anything left to add to this amazing Rig. it’s super fast and quick. Total Run time is 5 minutes.
So... here is the deal.
I’m looking for 950.00 or Best reasonable offer
If you want a complete upgraded EXB Roller with all the bells and whistles and all the upgrades done.
This is your truck.....
Spektrum SR6100AT 6-Channel DSMR DSM2 Receiver (RC Surface) with AVC and Telemetry: SPMSR6100AT, Black
ARRMA Rear Wing Outcast, ARAC9660
ARRMA AR320366 Wheelie Bar Set Outcast: ARAC9493,Black
Castle Creations Mamba Monster X 8S 33.6V ESC with 1717-1260Kv Sensored Motor Combo, CSE010016503
PPS complete motor and center Diff mount
BasherQueen Carbon fiber Esc mount on the way
Castle Creations B-Link Bluetooth Adapter, CSE01101350
Spektrum GPS Telemetry Sensor, SPMA95870
JX CLS-HV7332MG High Torque 32KG Metal Gear CNC Standard Digital Coreless Servo
Hot Racing AON21M01 Aluminum Steering Blocks Hd Bearings Arrma Kraton Outcast
Hot Racing AON311M01 Aluminum Center Sway Bar Mounts Arrma Kraton Outcast
Hot Racing AON4801 Aluminum Bearing Steering Bellcrank Arrma Kraton Outcast
Hot Racing AON09RR01 Aluminum Rear Lower Rear Suspension Arm Mount Arrma 1/8
Hot Racing AON12C01 Aluminum Gearbox Case Bulkhead Cover Arrma Kraton Outcast
Hot Racing AON24M02 Aluminum Steering Servo Mount Arrma Kraton
Hot Racing AON48SH25 Aluminum Fixed Link Steering with 25t Servo Arm
Hot Racing AON22M01 Aluminum Rear Hubs Hd Bearings Arrma Kraton Outcast
Hot Racing AON12E01 Aluminum Hd Gearbox Case Bulkhead Arrma Kraton Outcast X2
Hot Racing ANN12RM01 Aluminum Center Brace Rear Mount BXL 6S
Hot Racing NRO10N02 17mm Serrated Close End Dirt Shield Wheel Nuts Arrma Nero
Hot Racing AON08FU01 Aluminum Upper Front Suspension Arm Mount Arrma 1/8
Racing AON08FR01 Aluminum Front Lower Rear Suspension Arm Mount Arma 1/8
Hot Racing AON09RF01 Aluminum Rear Lower Front Suspension Arm Mount Arrma 1/8
Hot Racing Lower shock mounts
Hot Racing AON40M01 Aluminum Wing Mount Arrma Kraton Talion Typhon
TEKNO RC LLC M5 Pinion Gear, 24T, MOD1, 5mm Bore, M5 Set Screw, TKR4184
Vinyl 3mm chassi gaurd
All stainless steel screws
