Do you have the V3? it was supposed to be better in the V3Ran in gravel today and had to turn the car over every minute because it would steer in only one direction due to a little stone.
It's a common issue, easy to fix, you need to screw the driveshaft back to the axle. But when you do use loctite as you're screwing into metal.After 7 minutes one rear wheel flew of. The 7mm nut was still in place with a piece of an axle. I'll have to figure out what that's all about
Also probably worth all 4 corners with loctite to fix this once and for all.
Note to let the loctite set overnight.
But real cars also have toe-in in the rear.
It's actually aids in straight line, for turns you'de better be without it. it also takes the slop out.
As for the fronts, toe-in balances the car to center, and tow-out to get off center, that's why the fronts is set with toe-out, to aid in turns. If you prefer driving in straight lines then set the front for toe-in as well like the rears. Neutral is not very good as there's no force on the wheels and then the slop is making the car is unpredictable.
The screw holding the axle came undone. If you are lucky, it will still be in the back of the drive shaft. If you are very lucky, you won't have lost the bearing off the axle.Ran in gravel today and had to turn the car over every minute because it would steer in only one direction due to a little stone.
Yep, bolt and bearing still in there! Went ahead and checked all. Man these things are looseThe screw holding the axle came undone. If you are lucky, it will still be in the back of the drive shaft. If you are very lucky, you won't have lost the bearing off the axle.
