Hello all,
Ive read through the forums and am still at a loss. I have my Big rock built to handle 6s. Complete metal drive train including slipper and metal Differentials with input gears.
My problem is I keep snapping/breaking the driveshafts. Stock CVDs are out the doorz, they can't handle the power or the way I bash. So I upgraded to the ARRMA AR310870 mega CVD slider set. I can attest, they do indeed hold the power beautifully. The problem is, there a hair to short. I am running rpm Typhon/BRCC arms, so there a bit longer than the regular arms for say, a Granite. When I install the mega CVD's, they barely connect even a quarter inch into each other. I'm not jumping, but if I hit good bump or do a slight roll, it's very easy for them to pop right off as theres no enough material making contact inside the cvd.
So a anyone have any suggestions? Is there any possibility I can use the upgraded CVD slider set from the 4S line
No.
ARRMA - ARAC3954?
I'm already running 17mm hexes. And I'm not opposed to modding anything to make them work. What do you guys think?
No.
ARRMA - ARAC3954?
