Iznapulipuli
- BigRock 4x4
- Kraton 6s
Hello guys. Apparently i don't know how to use the internet but i had a hint from the forums that if you upgrade your 3s BRCC with typhon RPM arms you should also upgrade the rod ends. So my question is, do you guys know the part numbers that would replace the stock rod ends (ARRMA RC ROD END SET AR330470) with stronger ones?
