Premium members don't see ads. Click here to upgrade.
Bringing a pawn shop Talion V1 back to life
beewerks
Longmont, CO
Talion
The problem with those tires is they were meant to be run on 6s power.
Yes, that's what I was worried about. Traction on dirt was amazing until the un-glued. What tires and wheels are recommended for general fooling around?
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast 6s, Typhon 3s
I would say either Proline 3.8 Badlands(not the MX3.8) Proline Shockwaves or Dboots Backflips, the Backflips are a bit on the larger size though. No matter what you buy they will ballon on 6s though.
beewerks
Longmont, CO
Talion
The backflips sound really good from what I've read. I'll see if I can find an affordable set of those. I'm also thinking of getting some Tekno orange springs since I'm finding that the front springs seem too soft in my opinion.
Notorious J
Traxxas spy, here to gather Arrma secrets 🕵️‍♀️
I'm from Mars but my wife is from Venus
Notorious, Outcast 6s
Notorious J
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Go with V3/V4 Kraton springs, they are longer and stiffer than the Teknos.
Primarrma
ArrmaForum Fan
Australia
Kraton 6s, Talion, Typhon 6s
Also the Talion tyres are great, they aren't stunt tyres though you can still do a back flip with them, they don't bring the car around in the air like the backflips do. The tyres you're running are great on a track, but not for a high speed run.
beewerks
Longmont, CO
Talion
Alrighty! So I received my new dBoots Backflip tires. They look really good and are HUGE. I'm excited to run them, but of course nothing is ever easy.
I bolted them onto my v1 Talion and found that they don't rotate at all. The hexes on the new wheels are deeper than the hexes on the truck so the hub on the wheel rubs against the axle carrier. I did some searching around and I guess there are two options. One is to grind down the hubs on the wheels so the hexes aren't so deep. I'm not a fan of that approach really but it would be easy. Option two is to replace the hexes on the truck with Kraton hexes from what I've heard. What I'm not sure of is what other parts I need to make the Kraton hubs fit my truck. Thoughts?
38300
38301
Primarrma
ArrmaForum Fan
Australia
That's a pain, how much slack is in the axle? If you were to remove the axle hex, put some shims between the outer bearing and the red hex, would that give you the clearance you need?
Otherwise Jenny's RC has a set of hubs, but is it the axle hex that is to too narrow?
If you change them I don't know if you will need all this?
https://jennysrc.com/products/arrma-kraton-6s-blx-driveshafts-front-rear-center-universal-cvd-ar106040?variant=19993710952502
https://jennysrc.com/collections/arrma-kraton-v4/products/arrma-kraton-6s-blx-17mm-hex-hubs-16-5mm-adaptors-wheel-red-nuts-ar106029
https://jennysrc.com/collections/arrma-kraton-v4/products/arrma-kraton-6s-blx-hubs-bearings-front-rear-uprights-blocks-ar106018
cootertwo
Military Veteran
Wow! That's a new one on me! I didn't know there was a difference in the wheels. To use the Kraton hex's you also need the Kraton axle parts. I'd wait and keep checking Jennys for the whole axle package. Cheaper. Others will chiome in as to what other models use the same stuff.
AR310591 2 each
AR310590 2 each
https://www.ebay.com/itm/ARRMA-AR310591-Wheel-Axle-8x45mm-Kraton-2/232295904138?epid=1237650681&hash=item3615ea338a:g:ZrAAAOSwVgZZut-A:sc:USPSFirstClass!34143!US!-1
https://www.ebay.com/itm/NEW-ARRMA-Kraton-CVD-Axle-8x44-5mm-2-AR310590/322734761456?epid=1534380477&hash=item4b247da5f0:g:XvEAAOSw~4NZtobl:sc:USPSFirstClass!34143!US!-1
Humm late to the party I am, as usual..... Ha!
Primarrma
ArrmaForum Fan
Australia
AR310591 2 each
AR310590 2 each
I can run Minokawas on my Talion, but they have a thin wheel hex, the Backflips have a deep hex for strength. I must try and see if the Backflips will fit the V3 Talion?
beewerks
Longmont, CO
Talion
I will tear apart the axle carriers and check since I didn't know that was a possible option. I feel like I only need 1 or 2 mm of clearance. Thanks for the links!
AR310591 2 each
AR310590 2 each
Yeah, I was pretty surprised as well! I'll watch Jenny's if it turns out I need to replace a bunch of parts.
Primarrma
ArrmaForum Fan
Australia
I use these(below, but any similar thickness shims will work) to shim the axles if there is too much play. I also use them in my diffs to tighten the mesh. I started using them instead of the large shim on the outside of the bearing arms put them on the inside of the bearing. Hopefully they might give you the clearance you need for your wheels though? https://plaig.com.au/product/shims-8x10-0-2mm-thickness-packs-of-10/
