Feindish
So I just fixed my granite and I hit a tree and broke the upper suspension link. I really like this thing but it is no where near as tough as my 6s outcast. Anyone have a good upgrade?
You hit a tree. I'll break something for sure if I hit a tree with my Outcast 6s TBH. And I have before. Sorry, I don't have any upgrades to mention. When I did have my granite BLX I never hit a tree, but broke the lower arms on rocks. No biggie. I just replaced them with stock arms. They are very durable. It took me a while to do that. Good luck.So I just fixed my granite and I hit a tree and broke the upper suspension link. I really like this thing but it is no where near as tough as my 6s outcast. Anyone have a good upgrade?
Have you tried the RPM arms? :So I just fixed my granite and I hit a tree and broke the upper suspension link. I really like this thing but it is no where near as tough as my 6s outcast. Anyone have a good upgrade?
Yeah that too. That radio on the more modern Granites has crazy lag time.Maybe a transmitter upgrade to one that's got a faster response time to help you to avoid hitting trees ?
But them trees never stay still for me. Curbs either ?yes new radio and time... to you learn to be better driver ?
I get magnet syndrome, wide open field and I end up going straight into the nearest hard object. ?But them trees never stay still for me. Curbs either ?
These granite length arms or Typhon length? And if Typhon length arms did you add the Typhon turnbuckles or just extend the granite ones out? The reason I ask is I been seeing people do the typhon arm upgrade and comment that just extending out the links of the granite turnbuckles is all they needed but I've tried that and it's barely long enough and I doubt it's strong enough to last and since you broke was just checking to see if that's the case or not.I have a fly sky radio and yes I do need to learn better control.
I have rpm arms, but it was the link above the a arm.
Which will lead to a busted chassis. You want the arms to break first.Granite arms
I could make some fixed length ones at work out of metal
By suspension link do you mean the turnbuckles? I have a Granite as well and while I haven't broken one, I've bent a few. Not only that, but they are always twisting around and have to be readjusted after just about every run. DrianRC recently posted a video where he replaced them with the composite links from the brushed Granite:
https://www.arrma-rc.com/part/AR330446
I haven't tried it yet, but I am going to. Downside is you lose adjustability. My setup is not so far from stock, so losing adjustability may be a worthwhile trade-off if they provide more durability and less headache.
Damn, I was hoping they would be really durable. Thanks for the info. I'll probably still try them out, as I just bent another of the brushless version one run after I replaced it.Mine is the brushed version and yes I’m talking about the turnbuckles. I made some out steel at work today I just need to machine them down a little so they fit, and drill a few more holes to reduce weight.
