Broken differential: Notorious
Thatonekid286
Roanoke
Notorious
Ended up breaking my differential within 5 minutes of unboxing my Notorious. Is this a common issue or can I be confident it was an isolated event?
bicketybam
RC Grand Champion
New Milford, CT
BigRock 4x4, Granite, Infraction, Kraton 8S, Kraton 6s, Kraton 4s, Mojave, Notorious, Talion, Typhon 6s
I'm pretty confident I could break one is less than 5 minutes. Punch 9, and just hammer the throttle over and over. Standing backflips for days.
Without knowing any of the details like what broke, what you were doing when it broke, etc. no one can really give you a good answer. You didn't even say which diff it was.
Thatonekid286
Roanoke
Notorious
Sorry, new to this. It’s the rear diff. I broke a planetary gear and a pin doing a standing backflip.
Camaroboy383
Invention is the mother of necessity!
Connecticut
4x4-Mega, Kraton 6s, Outcast 6s, Outcast 4s, Typhon 3s
its common.. standing backflips and landing on throttle will take them out.. the pin shears first, then the pin rotates through the bore of the gear and pops it.. you can use better pins and gears, or stop doing standing backflips and landing on throttle.. if it broke in 5 mins id guess you were flipping it on tar?
bicketybam
RC Grand Champion
New Milford, CT
Yeah there's a good chance of breaking those when you do standing backflips. You have to have good timing. You need to bee off the throttle when the flip lands.
Thatonekid286
Roanoke
Notorious
I was on grass actually. The center is messed up as well. I’ve apparently got a lot to learn.
Hoss81
Granite, Kraton 6s
Inside of the case. Day one, broke the truck lol. My buddy said “welcome to RC”
Yep, unfortunately the power density of Lithium batteries and brushless motors has evolved faster than the design and size of the diffs in our vehicles. Standing Backflips will roast a diff pretty quickly. You can shim both the inside and outside to make the diffs as tight as possible without being too tight, this helps a little. Oddly enough I've never broke a spider gear in my Kraton and I'm running a 4092 motor. I've typically had issues with the diff pinion which is more related to a shimming issue than it is me mistreating it.
Create account
Log in
