ArrmaGraniteState603
- Granite
Granite 3S BLX
Bearing at the end of the motor shaft inside the motor housing broke today, causing the shaft magnet thing to rub all over the inside of the almost circuit board looking material that it’s supposed to spin around. I’ve got most of this black soot off the shaft itself but there’s still a decent amount on above mention circuit board green thing it sits in (hope that makes sense). Is it even worth cleaning if, if so, certain type of solution that would work best? I feel like if I could clean it all out it’d be fine, I’ve replaced the bearing already but the soot is still causing friction.
Clean it and try to save or just get a new motor? ANDDD If I get a motor, what would you suggest? Heard wth a higher KV motor I might have to change to a different pinion? I have 13T and 15T pinions currently. Already upgraded metal spur gear no issues there. Thanks guys.
