Notorious J
It's gonna break, so might as well send it!
ArrmaForum Fan
Hospitality Award
Rig of the Month Winner
- On a midnight train to nowhere
- Gorgon
- Granite
- Notorious
- Typhon 6s
Like many of the fans I keep hearing about, it seems the violent force of some of my jumps caused the slide on the switch to snap off. It didn't break loose from the truck, but somehow managed to break anyways. It is still in the on position and works, but only by disconnecting the battery can I turn the esc off. Had a spare, so switched immediately, but my question is, if I hold the set button while plugging in a battery, will I be able to get into programming mode? I had considered splicing a switch from a toasted unit, but all three wires going from the esc to the switch are the same color, so next to impossible to know if they are going to be connected properly. I might be able to mark the wires by holding them side by side and color coding accordingly, but it seems a bit sketchy. Anyone ever run into this problem before?
