Correction the piece that attaches the shown part is cracked. I guess that is a tie rod. Trying to figure out what to order? Having trouble locating it in the drawing.
Thank you. I see now that I can probably just replace the plastic piece that is broken at the end of one turnbuckle using 1 piece from the set?Composite ball cups https://www.arrma-rc.com/part/AR330230
Yup just replace the broken one with the matching one out of the bag. Make sure you take a measurement of the length of the completed turnbuckle before you take it apart so that you know how long it needs to be when putting it back together since Arrma doesn't list these specifications anywhere.Thank you. I see now that I can probably just replace the plastic piece that is broken at the end of one turnbuckle using 1 piece from the set?
