carckton driver
- Kraton 6s
you want your wing mount to give and take the impact. the way 3drc designed his mount it does just this. it will twist 90 degrees and soak up all the impact. this protects everything. less force transferred to the bulkhead, to the shock tower and even the screws holding it on. in my opinion a better design would be next to impossible to make.
i can verify 3drc wing mounts wont break, and they wont create ANY other weak points either like i mentioned3d-rc.myshopify.com there are some wing mounts here that have been beefed up and wont break
or get them while they arent cheap. its COMPLETELY worth your normal price and if the one i have on my car ever breaks i wont hesitate one second to spend the normal selling price for another pair.www.3d-rc.online we are having a Black Friday deal. Get them while they are cheap
wrong. no wing mount screws to the shock tower. they all however screw through the shock tower to the bulkhead, just as 3drc does.So I see that it doesn’t mount onto the shock tower. Am I right?? Typically the wing mount does screw into the shock tower.
you sure you bought the right wing mount? or maybe more likely you sure you received the correct one, have you checked part numbers to varify? it was admitted to me that he HAD someone doing shipping that wasnt good (this has been taken care of), one of my orders got messed up.My only complaint with the 3DRC mount is that it does not have the same profile as the stock mount and the wing sits at a different angle as well. It was so bad on my Kraton I even made a thread about it. Https://www.arrmaforum.com/threads/what-did-i-do-wrong-here.53817/
