Brushed motor stopped working
FuryJawa
Kentwood Michigan
So I was running my Fury around today. Running the included NiMH battery. That died, switched the jumpers and plugged in my lipo.
Now it won't run. Lipo is fully charged. The ESC lights up but doesn't make the normal sounds when you flip the on switch.
What should I do. The motor is free of debris. And turning just fine.
Thanks in advance
There are not many options on the Mega ESc: you did set the connector to lipo batteries?
Nevertheless even on the ni-mh setting your truck should work.
What do you mean with the ni-mh battery died?
Does it not work as well?
It sounds like a bad Esc. With brushless motors the "beeps" when you turn on the car are made by the actual motor.
With a brushed Esc. it is not.
If you can try your ni-mh battery to make sure it is not your lipo or motor
A friend of mine has the brushed fury. I'm only driving brushless but what could I advise him for replacing his motor? The stock Arrma 15T 540 motor died for the 2nd time.
How many battery charges should this engine last?
A great inexpensive brushed motor for Arrma Fury Mega is the Traxxas Titan 12 T motor. It's plug and play. The motor rips, I finished 3rd against a field of brushless 2wd SCT trucks using the Titan.
Best regards,
Brian
Hi guys
My arrma raider stopped working and when i start it turns but wouldnt reverse or go foward. It doesn't give me the 2 clicks. Any idea what the problem might be???
