Mustangman66$
- 4x4-Mega
- Granite
- Outcast 6s
- Outcast 4s
hello hobbiest I was about to order the hobby wing max 10 with 3300. I was want to know if the stock pinion work with the motor and if not what do I need to make it work. Just wanted some info on if this like drop in ready deal.thank you
What would be to best size to start with tooth count
I dropped the "Hobbywing 38010203 Max10 ESC Combo with 3652SL 3300KV Brushless Motor" from Amazon in the old granite on Thursday and took it on a 4 day camping trip, and it did great. It's got enough power to wheelie on 2s with a 17t pinion, which on the 3652 is still 3.175mm shaft. (The 3660 has a 5mm shaft) Temps never got over 170ish running in the grass. Everything else held together despite being completely stock. So far, not too shabby.What would be to best size to start with tooth count
The 5mm shaft is the one that a Main has in stock and I want to get the motor and esc together not separate if I can
