Darren Wes
Be gentel when you start using the brushless so you don't break gears or strain anything too hard
Esc
http://www.amazon.com/gp/aw/d/B00DU...ds=60a+esc&dpPl=1&dpID=512UnXZjt2L&ref=plSrch
Motor
http://www.amazon.com/dp/B00GV5YX6U/ref=sr_ph?ie=UTF8&qid=1432444866&sr=1&keywords=3900kv+brushless
I used this setup with an onyx 5000mah 2s 25c tonight and walked for a whole hour about 1 mile drove maybe 2 miles. I was going about 20-40% throttle for about 60% of the ride and the rest was spent on the grass... poping wheelies (its a bit tricky but possible on 2s)... and full throttle. Very satisfied for about $40-50. At the end of the run i was at about 150-160degrees
I would suggest a either the onyx i have or maybe even a smaller lipo.... i also got and hour run out of a 2000mah though i stayed under 60% throttle the whole time ...maybe a 4000mah soft case would be a nice give and take on weight and not giving up a big amount of battery storage... you could do 30c with a 2s but your temps will rise faster. But you will probably have a little bit easier time doing wheelies , if you don't want to try your luck at 3s.
I got a new 4000mah 3s lipo 20c in the mail gonna try my luck on the real streets!
Esc
Motor
