If that is a 2-pole motor there will be no problem using the stock gearing
(Edit: the Amazon links confirms this)
However since this comes close to the 4000kV 45A ESC from the BLS version, you could have a look to the gearing of that Fury: 22t/87T
So it is only invest in a 48dp 22t motor-pinion.
And maybe a even larger one is possible, hence it does fit.
The pitch distance from center motor axle to center spur gear is off course limited in the minimum and maximum offset
