No a brushless motor shouldn't rattle. Could be a bearing or a magnet.Hey everyone, just tore apart my Granite, decided to check if the motor is tightened in properly, found out it makes a weird rattling sound when you shake it around. Is this normal? What should I do if it's not?
Alright gonna do ASAPNo a brushless motor shouldn't rattle. Could be a bearing or a magnet.
Just screw it open an see what's inside.
Alright I disassembled it and it's completely clean inside, only the rear shims are completely bent, which I don't understand. But the motor makes the rattling noise even when the rotor is outside of it. Any idea what this could be?No a brushless motor shouldn't rattle. Could be a bearing or a magnet.
Oh thanks for the answer then. But the silent pacing sound still makes me worry a bitI have bent shims in my motor , I would not worry.
This is the sound it makesWow very bent up. Video?
Edited pics popped up late for me.
Don't see any stones in thereThose shims are supposed to be bent. They are preload springs that keep the rotor centered. With out them the pinion gear can walk the shaft in or out and can move enough to wear out the spur gear or break gear teeth.
as for rattling check to make sure theres no tiny stones stuck in the motor windings sometimes they rattle faintly.
Motor bearings shotHey everyone, just tore apart my Granite, decided to check if the motor is tightened in properly, found out it makes a weird rattling sound when you shake it around. Is this normal? What should I do if it's not?
Ok so you hear this sound when you shake the motor without any moving parts left in it? (rotor, shims and bearings front and rear)Oh thanks for the answer then. But the silent pacing sound still makes me worry a bit
I can't think of anything else than some sort of debris. Do you have an air compresser to blow it out?Yeah
im honestly not sure why it's making that noise... it is very strage that it makes noise with nothing inside... maybe the motor casing is hollow on the inside (double walled or something) and debris is inside somehow??? or maybe it's just ghost rocks bouncing around inside... oooooooohhh spoooooookyy (insert scary noise here)I don't, I inspected it more thoroughly and there's just no debris visible
Strange really
Very spooky indeedim honestly not sure why it's making that noise... it is very strage that it makes noise with nothing inside... maybe the motor casing is hollow on the inside (double walled or something) and debris is inside somehow??? or maybe it's just ghost rocks bouncing around inside... oooooooohhh spoooooookyy (insert scary noise here)
