maddmatt02
- 4x4-Mega
So the other day I thought it would be cool to record my emaxx blasting through our pumpkins in slow mo as it flew off of the jump. First round was a success but the 2nd pumpkin was just too solid still so now I need a chassis and braces for the maxx. Also I kinda hate working on it these days because there's just so many screws and hard to reach nuts (RPM bulks, etc) that I decided for now to sacrifice the truck to build something else. I also smoked the cheap esc that was in the senton mega the other day. Landed after jumping over my truck again and just made a big ol smoke show and the 120A I had in the box as a spare is pretty crappy. once rolling there is no delay in additional throttle but from a stand still there is a TON of lag before it gets going. so instead of 2 crap trucks I'll build one good one.
I went over the exploded views of the big rock and senton to see everything that was different. I am going to skip plenty of it for now but heres what I'm thinking, anybody think I should do anything else? (this is the short list because it's trying to be "budget")
*HD 17T input gear on the rear (might go to the 13/37 setup front and rear when not back-ordered/if needed)
*BLX driveshaft/center bearing (haven't checked if I have the provision to mount it but both chassis has same part number but I'm guessing maybe old ones didn't new ones do... just like the new/old front skid having same part #s) And I cant tell from pics if they spline count for the shaft/inputs are the same...
*BLX 32P spur/slipper (If I can find it anywhere in stock...)
*Granite/Big Rock body posts
*MAXX chevrons on 14mm RPM stablemaxx wheels (probably need to)
*Fast Eddy rubber sealed bearings everywhere
I am going to try and fit the pro line c10 thats on my MAXX, think it will work the senton body sits on the maxx and looks like a huge SCT... wheelbase lines up pretty good. going to steal the waterproof 120A 4S esc and 2250kv 4074 out of the maxx.
for wheels and tires I have some stock old maxx wheels with the chevron tires and then I have some 23mm hexes and MGT 8.0 wheels I currently run on the MAXX but I don't think either offset is any good so I'll probably get some 14mm stablemaxx wheels and swap over the chevron tires.
eventually will either get the springs for the big rock or swap over to different shocks like the alum HSP ones on ebay that I think Megasty linked to on this site elsewhere. front shocks leak bad and if I try and tighten too much the o rings bunch up/pop out so I either need new cartridges/o rings or new shocks or something.
Will run on 3S until I get some 4S batts that will work. my pair of 2S I run in the maxx uses bullets and it might be tricky to make both work in the senton chassis. I have an idea but not sure it will work yet.
