SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
Windshield is a must to keep the nose down approaching 50mph. I left the side windows open. In stock trim the rear louvered vents can't expel the air coming through the open windshield. So the nose wants to rise. ST gets compromised easily at speed. I run 6s also with stock electrics and the 16T pinion. Always cool. I have never went thermal cut. Not once ever. Even in hot temps. I have a PH double turbo fans/HS setup on the stocker 2050 motor. I use the optional fan standoffs to raise the fans above the HS FWIW. Opened up one fan hole of the cockpit above the motor. Im sure opening up the other hole would even work better? And may help better with some of the Parachuting effect? But the Mojo doesn't seem to suffer this much like all other 1/10 scale SCT do.
Using the Scorched Rc liners also.
