Best thing to do take it apart clean it pur red threadlock on the rear slipper hole where the screw go in 1.25 turn from tight to be sure it wont loose on you thats what i did when i had enough its conplicated to take apart after but well worth itI plan on replacing those as well as fixing the old Slipper since I bought a whole new one I'll just make sure it doesn't build up any heat and keep my eye on it This time Since the factory Slipper wasn't set right from the factory Cause that's the 1st thing everybody keeps telling me was the adjustment was right I'll just keep on adjusting until there isn't a lot of heat build-up
Also a bit on the end threads
What people has described is the hot rscing alluminum yokes seems to fix the issue of diff stripping in the rear
Here is my rear diff gears after a month with a bad gearmesh
vs new one
You see the gaps of the gears are conpletly differant
The fatal issue to me seems here is to make the diff spin freely like a baby butt from new by moving the shim to the other side or shiming it that way
after a while the gears will only have pretty much 60% gear contact and its going to wear
And in fact most people breaking diffs is on the jratin 4s owners because a lot more stress is put in the rear than the outcast short wheel base can wheelie like if it was nothing while the long wheel base not so much you see
