- Kraton 4s
- Outcast 4s
- Outcast EXB
- Talion EXB
So, after shearing the tabs on the back of my sun gear, on two different EXB diffs, was time to try some things different.
First diff was on the Outcast and a front still in LSD configuration. After giving it some thought, when in maximum diff effect the round LSD plate is applying direct diff action pressure on the tabs located on back of sun gear as the stationary star plates apply friction to the round plate. Don't like this design that much. Yes, I was hard on the diff... but found this to be the weak point.
Switched the diff to full open with the Arrma shim kit. Only have one pack in it, so no issues with it yet.
Second diff was on the Kraton, and the rear. This one was already converted to full open with the Arrma shim kit using the large 1.8mm thick shim. Sheared the sun gear tabs and then the pin on the outdrive sheared due to the sudden impact and not having the tabs to help support it.
So. After some thought and seeing what @Engineer did, I think it is best to not use just a large or stack of shims with full open, but to use (2) of the round LSD plates on the back of the sun gear, then add a round 12 x 17.5mm shim to the back of that to create a total shim thickness of 1.8mm. With just the large Arrma shim, 1/2 of the outdrive pin is bearing pressure on just the sun gear tabs. Using the round LSD plates gives these tabs support, and should help them not shear.
Test run will be in the morning, but have to say...this diff feels perfect!
