Toiletpimp
Typhon. If it flies right the rest will follow!I'll be testing my ramp tomorrow. A y suggestions as to which truck should go first? Kraton, Talion, Typhon, Granite, BRCC (Noto on the shelf).
Nice rampI used a bendable piece of flat pvc to get my curve at 40 degrees on the transition. I felt 45 degrees might be too much. Yours looks right to me. 4'wide
Here are photos of the one I built with my dad's help. He had the tools and the skills but I think I could do it alone now.
Mine is heavy so I don't really take it anywhere and it's too big for my yard. The truck I built it for was way, way too weak to handle it but it's gone now and I still have the ramp. I thought about putting outdoor carpet on it but I was already at about $80 or so even after using some scrap plywood so I called it done.
https://photos.app.goo.gl/R8FD3oHcjNDGrJnm7
TALION!I'll be testing my ramp tomorrow. Any suggestions as to which truck should go first? Kraton, Talion, Typhon, Granite, BRCC (Noto on the shelf).
View attachment 38870View attachment 38871View attachment 38872
Honestly I don't think anybody gives a $@#t what goes first! We just wanna see it! Hopefully better documented than the ramp build itself...TALION!
Lol Jesus... Mad vert!!
Fuk... I wish I saw this earlier. That is gonna be a Booom, bottom out banger! 25 foot run way will do ya. Lol. That's gonna be a slow hitter.
It's pretty steep man... But no biggie you can always have another less steep. This looks like a high air trick ramp.
I usually Start out mild and slowly increase vert based apon style of ramp. Definitely no need for back either. Next time just stop by with beer and wood ?
What's that in inches... ?I've planned my ramps but just haven't had a chance to assemble them, maybe in a few weeks. I'd love to build something like the ones in this post but I need them to be mobile and fit in the back of my vehicle (I don't have a ute or dual cab) hence they need to be robust and collapsable. Attached are my rough drawings. At the moment I'm thinking 1200mm long 900mm wide and if the top is wider on two of the three then I can connect them as well. Notching the support arm will give me three variations of pitch but I won't have a curve. The actual ramp will also taper at the rear unlike the drawing (limitation of my drawing to draw.io).
Just need to find time.
The lip on the approach may be a challenge but sure enough, I do love the versatility. Maybe a piece of tin that could attach and make it for any angle and get over that first little bump.I've planned my ramps but just haven't had a chance to assemble them, maybe in a few weeks. I'd love to build something like the ones in this post but I need them to be mobile and fit in the back of my vehicle (I don't have a ute or dual cab) hence they need to be robust and collapsable. Attached are my rough drawings. At the moment I'm thinking 1200mm long 900mm wide and if the top is wider on two of the three then I can connect them as well. Notching the support arm will give me three variations of pitch but I won't have a curve. The actual ramp will also taper at the rear unlike the drawing (limitation of my drawing to draw.io).
Nah the lip won't exist. It only appears on the drawing because I can't do the angle on the shape well with Draw.ioThe lip on the approach may be a challenge but sure enough, I do love the versatility. Maybe a piece of tin that could attach and make it for any angle and get over that first little bump.
@bicketybam looks like an interesting project. I love working with wood.!!!
I need to add TBone bumpers first!!!?Send the brcc
Their strength will destroy your ramp. I'd stick with RPM if you want to keep your ramp looking new. ?I need to add TBone bumpers first!!!?
But I love the challenge of installing T-Bone parts!Their strength will destroy your ramp. I'd stick with RPM if you want to keep your ramp looking new. ?
Simple bolt ons are for wusses. T-Bone is keeping the spirit alive, by making the hobbyist have to think and modify to get the job done. It's all part of the plan to make us smarter, and not just RTR junkies.But I love the challenge of installing T-Bone parts!
