- Cleveland, OH
- BigRock 4x4
- Infraction
- Kraton 8S
- Kraton EXB
- Senton 3s
INTRO
I completed my Senton to Big Rock conversion the other day and I have been ordering parts to build an EXB. I decided to try out hot racing parts so I’ve ordered mostly everything they have for the EXB.
I started tearing the rear of the truck down today. End result is one removed the rear bulk head and everything attached to it. I’m waiting on parts to reassemble it.
I’ve never done this before so I’m excited to learn a lot! Soldering, ESC tuning, gear ratios, differential fluid swaps and shimming, etc.
PARTS LIST
Kraton EXB Roller
Hot-Racing:
3DRC Wing Mount: Black
Wheels & Tires:
Servo:
ESC & Motor:
Receiver:
Radio:
Pinion Gear(s):
Ordered but not (yet) installed:
Wish me luck…
PARTS LIST
Kraton EXB Roller
Hot-Racing:
- AON12C01: Bulkhead Cover
- AON12E01: Bulkhead
- AON311M01: Sway Bar Mounts
- AON21M01: Steering Blocks HD
- AON22M01: Rear Hubs HD
- ANN12RM01: Center Brace Rear Mount
- AON08FF01: Front Lower Front Suspension Arm Mount "A"
- AON08FR01: Front Lower Rear Suspension Arm Mount "B"
- AON09RF01: Rear Lower Front Suspension Arm Mount "C"
- AON09RR01: Rear Lower Rear Suspension Arm Mount "D"
- AON40U01: Wing Buttons
- ANN12FM01: Center Brace Front Mount
- ANN14RN01: Upper Chassis Brace Rod Ends
- AON08FFB02: Super Basher Front Bumper Mount
- ANN38A02: Center Differential EZM Mount
- ANN38C01: Center Differential Cover
- AON331M08: Steel Skid Plate Set
- AON48SH25: 25T Servo Arm
- NRO10N02: 17mm Serrated Close End Dirt Shield Wheel Nuts Arrma Nero
Wheels & Tires:
- PRO1015510: Pro-Line Belted MX38 Trenchers
Servo:
- SW-2290SG-BE: Savox Waterproof Premium Brushless Digital Servo (Black)
ESC & Motor:
- CSE010-0165-02: Castle Creations Mamba Monster X 8S 1/6 ESC/Motor Combo w/1717 Sensored Motor (1650kV)
- CSE011-0135-00: Castle Creations B Link Bluetooth Adapter
Receiver:
Radio:
- SPMR5025: Spektrum DX5 Pro
Pinion Gear(s):
- Saga Customs 18, 20, & 22 tooth pinion gears
- HRAAON133XC: HD Bearing Wheelie Bar Set - currently lost in the mail
- AON40M01: Wing Mount - Went with 3DRC instead
- AON12WM01: Rear Brace and Wing Mount - hasn't arrived in mail yet
- AON4801: Steering Bellcrank - lost in mail
- AON08FU01: Front Upper Suspension Arm Mount - didnt seem to fit? Idk.. kept with EXB part
- AON1101: Differential Carrier Case - Decided not to take apart the diffs just yet
- AON11ETN02: Modular Differential Case - Decided not to take apart the diffs just yet
- AON331M08: Steel Skid Plate Set - Rear installed, front does not really make sense with EXB Super Basher Bumper
- SPMSS6280: Standard Digital HV Ultra Torque High Speed Waterproof Metal Gear Surface Servo - went with Savox instead
Wish me luck…
