KrazyKraton14
- Thread starter
- #61
Vids from this weekend
They look fine for some reaso. Did a whole 45min ride around the block trying to set the alignment AGAIN. lol.How was the fitment of the rear a arms? Mine were binding pretty bad and I had to sand them down to clear the rear bulkhead.
Your servo is still on backwards.
I bought the same hot racing axle carriers was it easy to take the pillowballs out?More pics
Oh wow...ok krazy thanks I might hold a little then don't have too much time on my hands right now...Im sorry i just have another quick question thats off topic if you don't mind....any idea what is going on if I'm running 4 then 6s with cool down time and all of a sudden my truck just dies, no throttle just steering...once I turn her off and back on again she's fine...I just wanna know if this happens sometimes and if its just a cause of overheating or something
ok at least I'm not the only one lolactually that happens to me, I had 1 fan on and that happens after about 20mins then just steering active, wait about 3mins and back in action.
found out it was heating up,hence I started to bring my temp gun and ended up switching from 1 castle fan to 1 heatsink fan from hobbywing but you can get dual fans also I feel that will help as well, also after new fan the only time it would die is after about 45mins it just stops, that when I know now I am out of battery. I use 2x 3s with 6700mah its pretty good no more troubles
do you have a fan on the motor?
maybe your battery doesn't last long?
maybe those two are the only thing im thinking off.
I have the stock fan on the esc and have a hobbywing heat sink and fan on the motor which I thought would definitely cool it down
I don't wanna burn up my motor so that's why I let it cool down and switch off with my raider xl. I was running the 14t pinion which broke yesterday lol the arrma ones definitely suck that's the second one that went.
When I started out I had a lot of traxxas batteries so I ended up buying xt90 to traxxas connectors...could that be something too
Nope! the only that isn't stock on my truck as of right now is the hobbywing heat sink and fan that's it...I bought some Robinson Racing pinions I have a 12 a 14 and a 16t maybe I'll go back to the 12
Thank you so much for your help!!try 12t or diff fan
anytime! that's why I made this thread for build questions and anything I may encounter I can share it to everyone here.Thank you so much for your help!!
