For Sale / Trade BUILT Arrma Outcast 8s EXB M2C GPM Vitavon Hobbywing RPM
dimaxxxl
Up for sale is my built to the gills Arrma Outcast 8s. The truck was built from the ground up with almost all new upgraded parts and no expense spared. Since the rebuild, I have only tested it in the yard so not even a full pack has gone through it. I’m not really driving my 1/5 trucks much because they require too much space so thinning the herd a bit. Below is a compete build list for the truck and hopefully I haven’t left anything out. Have a few wheel options if you don’t like the wheels on it. Feel free to let me know if you have any questions. $1500 shipping included in the continental US.
Hobbywing 1100kv motor Max 5 Esc
Dual hyperflow motor fans
YR upgrades Esc fan
Savox servo
Exb outcast 8s chassis with chassis skin
Exb motor mount with both slides
aluminum support brace mount
M2c axles all around
Gpm front and rear aluminum bulkheads
GPM Shock caps
Gpm servo mount
Gpm servo saver
GPM top plate
GPM front and rear shock towers
Gpm pin aluminum retainers front/rear
Gpm front steering links
Gpm top plate
Gpm rear stabilizer links in the rear
Gpm 11mm hub extensions
GPM wheel nuts
Vitavon limiting straps
Vitavon shock collars
Enron aluminum wing mount
Enron aluminum wheelie bar
Enron aluminum front & rear hubs & carriers
Enron aluminum center trans case
Rc screws stainless steel screw kit
fast eddys bearings whole truck
Rpm Arms all around
3D printed Extended battery trays
Proline badlands
3D printed front bumper support.
If there is no price on it, is it free?
GLWS. O8S is my favorite rig. Had to check out your build log.
What’s the price really?
It states it. In the description. $1500 shipped.
YR upgrades Esc fan
Savox servo
GPM Shock caps
Gpm servo mount
Gpm servo saver
GPM top plate
Gpm top plate
GPM wheel nuts
Rpm Arms all around
Proline badlands
Hey Fam,
That's fire!!!!! That's a beast to keep! what's the weight now?
It’s so built to the gills I bet it can breathe under water. Nice job. You went hard on that Rig. Why do the work when you can buy this for cheaper than doing it yourself and everyone wants to have a Mack daddy build that spared no expense. GLWS
