ParkRacing
- Thread starter
- #41
Was he running 4s, and how many of those have failed on you? Also do you find the outdrives so poorly machined that you need to pry the planetary gears off, or need players to remove them completely from the diff case? I have had almost 30 models in the past ten years and never had such weird issues before. Build them and forget them... no issues!View attachment 4679 Cracked open son's Typhon center diff to check for carnage and why last bash ended in rear wheel drive only. Another failed planetary gear, pin was intact, should have shimmed his with TD planetary shims, just hadn't gotten to it yet. Granted last bash was over the top, borderline RC abuse, terrain was too big for buggy, but that little Typhon still kicked butt. It really is a compact, tough mini beast. I went ahead and truggified it with Kraton axels, hex's, hubs, and Proline 3.8s so my son can hang better with Kraton and Outcast on bigger terrain. Note to self, shim diffs before breakage, cheaper that way....Lol.
PliersWas he running 4s, and how many of those have failed on you? Also do you find the outdrives so poorly machined that you need to pry the planetary gears off, or need players to remove them completely from the diff case? I have had almost 30 models in the past ten years and never had such weird issues before. Build them and forget them... no issues!
