Does anyone have the factory specs for the camber, caster, and toe-in on the Felony/Infraction?
Thanks in advance!
Thanks in advance!
Whatever that Chinese guy felt like on the day he assembled it. ?Does anyone have the factory specs for the camber, caster, and toe-in on the Felony/Infraction?
Thanks in advance!
The factory lengths of the links are a more useful number than the angle. Measuring the angle will always have a range of variation. The length of the links can be measured exactly. In my experience, they come from the factory set intentionally and consistently. I don't own a Felony/Infraction, so I don't have numbers for you. I can tell you a V2 Granite BLX comes from the factory with 70mm front camber links, 67mm rear camber links, and 57mm steering links (measured from eye to eye).Does anyone have the factory specs for the camber, caster, and toe-in on the Felony/Infraction?
Thanks in advance!
This is a great tip! I also think tire wear is the best way to adjust camber to suit your driving style. I used wear over time, but it obviously took many runs to adjust. This is much faster.with new tires drew lines across top tires in equal quarters and drove it lightly to see the wear
