Recovery Infraction
- Infraction
Is there an old fashioned way to check camber on the Infraction while it's sitting on a workbench? Not by looking at tire wear and without a gauge?
Do you have a square for woodworking? If not, try anything that has a 90 degree angle that you can put up against the tires.Is there an old fashioned way to check camber on the Infraction while it's sitting on a workbench? Not by looking at tire wear and without a gauge?
I don't have any such tool, but I can improvise I'm sure..also, I'm assuming to get a base I should have batteries in RTR to get the sag correct ? Thanks btw!!??Do you have a square for woodworking? If not, try anything that has a 90 degree angle that you can put up against the tires.
