First RC, time to see how deep the rabbit hole goes.
I have Hurd good things on the tires it comes with and it has sealed bearings all readyI’m thinking a set of belted tires and a set of paddles. Gonna do a full tear down after I run through a few battery cycles and see what’s wearing, but parts wise first will probably knuckles and sealed bearings throughout. Then do some customizing of the body. Remove the “troops” insert and make a side by side style interior. Definitely lights and a dash mount style GoPro style for fpv style driving. Any suggestion on weaker parts to look out for?
No real big jumps yet, I don’t plan on doing that until I learn how to control it on the ground lolSpare sealed bearing are indeed a must. Make sure you check the diffs also. It is absolutely certain they are low on fluid.
Personally, the first structural upgrade I'd do is replacing the plastic chassis braces with M2C (or other high-end 7075 braces) if you intend to send it on big jumps. It seems they are holding up so far on the Fireteams out there... but I'm not too sure why, as they have always been one of the weakest link in the Arrma 6s vehicles.
I read that the ball ends can pop out of the plastic knuckles if they impact and to replace them with aluminum. I live close to a bmx track so that’s probably where I’ll be running it the most. Gonna do the bearings or at least get a set because I live in the valley in Oregon and it’s wet 9 days out of 10 until summer so I foresee them rusting
From what I've seen, the Fireteam tires are already good at not ballooning and maintaining stability and traction at top speed. It looks like they were designed for it. The Fireteam tracks completely straight at top speed. I have a feeling people will start using Fireteam tires as an upgrade instead of heavy belted tires. Belted tires may be a downgrade.I’m thinking a set of belted tires
