jerseydrew
Looking to swap out my motor for something the may run a bit cooler. Can this be done with the stock firma esc? If so what motor choices are out there?
Wouldn't a larger motor be able to generate more magnetic force per kv, thus giving it better ability to drive the same gear with less heat (Or in this case, a bigger gear with less kv). If I am right @jerseydrew didn't want to overload his esc and cause a fire.Less heat can only be done with a lower kV motor, ESC has really nothing to do with it.
You have to look at motor spec and look at the rated current, that will determine ESC size.
Plenty of options out there.
Length or diameterLarger, as in larger diameter?
In principle, yes, it also has a larger surface to dissipate heat. On the other hand, you also add more wiring inside the motor which comes with larger gap loss and all kinds of other non-intuitive issues.
Motor efficiency is where the heat originates, and lower kV will always win.
Get some fans and lower your esc motor timing. Stock timing is too high imo. I run a 16t pinion without trouble so with stock gearing that should fix it for ya.I run stock gearing. i am already looking at some fans
That’s the mount I use on all my rigs for dual fans. It solved the heat issues on my heavy Mojave and I’m running a 19t pinion. That’s with a Max 6/1650 combo though, so your results may vary…. But yes, the fans make a huge difference on any motor.Pick up one of these and two 40mm high speed fans and you shouldn't have anymore temp issues.
https://www.islandhobbynut.com/prod...luminum-40-42mm-dia-motor-mount-30mm-40mm-fan
Most of the popular rc manufacturers use the same size cans for the same size KV up and down the range +-100kv. It's all pretty standardized at this point. There might be the odd generic manufacturer on eBay or AliExpress but that's going backwards in reliability imo which is the point of increasing cooling.I'm curious how many of you have actually observed with a thermometer the reduction of heat with a larger motor can size. I personally have not done it but suspect it may be negligible. Reducing the kv and introducing fans would probably be way more noticeable and therefore worth doing. Technically increasing can size also ads weight. I'd try to start cooling where it counts and that's with reducing kv and fans. The closer you are to the max RPM of the motor, the more you should expect stress of the motor and therefore heat. Most bashers are going to be in the 33k-38k rpm range. If you're above that, then just realize you're over the "normal" top threshold. Each to their own.
I assume everyone runs fans just like I do (terrible assumption, i know), so for me going to a 4092 like i did was the obvious choice. Cooling wise it allowed me 2x 40mm fans on the motor and the "cooling fins" for superior heat transfer, vice the stock where you could only squeeze 2x 30mm fans over the can and the can was smooth.I'm curious how many of you have actually observed with a thermometer the reduction of heat with a larger motor can size. I personally have not done it but suspect it may be negligible. Reducing the kv and introducing fans would probably be way more noticeable and therefore worth doing. Technically increasing can size also ads weight. I'd try to start cooling where it counts and that's with reducing kv and fans. The closer you are to the max RPM of the motor, the more you should expect stress of the motor and therefore heat. Most bashers are going to be in the 33k-38k rpm range. If you're above that, then just realize you're over the "normal" top threshold. Each to their own.
That makes. I don't have this car, so don't know the specifics for application. I just understand the overall ideas with my recent 2S and 4S arrma builds. What you've mentioned though furthers my suggestion that for the OP to achieve better cooling, to reduce kv with the same motor size and add a fan.Most of the popular rc manufacturers use the same size cans for the same size KV up and down the range +-100kv. It's all pretty standardized at this point. There might be the odd generic manufacturer on eBay or AliExpress but that's going backwards in reliability imo which is the point of increasing cooling.
What you're saying is technically right probably but not feasible in the real world. For rc cars anyways.
