Monsterbasher8's
This is a huge motor&esc I know it going to need a 8mm bore because the shaft is huge
Thank you alotUse the calculator to figure out what you want.
I recommend starting at 100mph then work towards 120. If you can get that far without crashes that make you quit then move on from there....
(just being honest and real about it)
https://scriptasylum.com/rc_speed/top_speed.html
Example data you need to plug in
