Can anyone else relate?
Megaladon_Senton
If you don’t turn around and stare at your RC.. you’re doin it wrong
I've literally been staring @ my on road typhon for the last hour trying to figure out how to put a tower to tower brace on it! So far I haven't figured out a way. This front body mount is just not letting it happen. Any solutions out there?
Yep, always check em out. Have rigs in different rooms, just doing things I enter a room, stop, check out RCs then proceed to task at hand. Sometimes have to stop twice and stare, going in, coming out, it's beautiful. ❤
What about making a custom CF brace like the one SRC sells for the Infraction/Limitless/Felony?
I bought a couple of the red ones & a couple different body post mounts from Jenny's that I was gonna try (would even cut them down if need be) but that typhon body is just so limited in real estate. It is stretched on a kraton chassis tho, could I just use a scorched meant for that?
Edit: something like this, when they get them back in stock
I don't see why not. I mean, it stands to reason that the chassis would dictate the length of the brace, no?
That's kinda what I was thinking. My question would be about mounting the brace, then still being able to use the original typhon body mount locations?
Oof, good question. I honestly couldn't tell you as I don't have one. Surely there's someone who would know though. I feel like every conceivable combination of parts has been tried by someone :) Open up a thread about it if you can't find any info on it.
Yeah Been there, It won't work. The body sits too low, mostly the front body post is in the way of a T2T.
A different Non-Buggy body is the only answer. Then you are looking essentially at a Notorious length T2T and will work.
