ian turner
You might be able to cut down on the wiring a little bit, if the vehicle ESC already has 2 connectors, to allow a pair of 3S packs.It should work fine. It's complicated though, and big with three hard cases, and heavy with all those wires.
I run one 6S battery wherever possible.
View attachment 272760 Can I run 6s with these 3 battery’s ?
Ok that’s what I figured I just wanted to 100% know b4 I went and burned something up lolIt should work but I wouldn't, that is some seriously excessive battery wire lenth. It will raise the inductance and possibly damage/burn up your ESC.
Ideally you want your battery wires as short as possible. Motor wire extentions seem to be fine.
Just had it laying around wondered if it would’ve worked lolYou Macguyver-ing here?
