Can I seal my diffs with brain?
The last Nero
Nero,
My nero has diff brain can I use silicone oil and seal the diffs?
chevys10zr2003
Minnesota, USA
Kraton 6s, Senton, Typhon 6s
I don't have a Nero but figured I would try to help. Do you just want to seal the diffs and use silicone oil or do you want to still be able to use the diff brain feature? If you just want to seal the diffs and use oil you should just have to remove the diff brain hardware and then you will have a normal non-brain Nero and you just have to find the threads on this forum for sealing up the diffs.
The last Nero
Nero,
I still want to use the brain
chevys10zr2003
Minnesota, USA
I don't see how that would work or be possible. The diff brain uses/needs the holes and to fill it with oil you need to seal the holes. I'm sure custom fabricating a bunch of parts it would probably be possible, but off the top of my head, I am not sure how.
Create account
Log in
