Can i use a 100c battery on my Mojave?..
Combo
Israel
  1. Mojave
  2. Senton 6s
So.. can i put that one in my Mojave?...
Cheers..
Just so you’re aware, the C rating is the amount the battery is rated to output. But what sets the amount of current drawn is the ESC. If the ESC only needs 10a then that is all it will pull.
That lipo you posted above is rated at 6.0ah and 100C discharge, which equates to 600A. Now I’m not going to say they are lying about the 100C rating, but there’s no way that little lipo is putting out 600A for more that a microsecond at a dead short.
That said, it could probably give you 100a continuously for a bit of time. If you try to pull 600a continuously the voltage will sag well below LVC and potentially harm the pack.
Ok..
So ive ordered these two... ?..
The size is ok...maybe i will need
To change the connector to EC5..
all i need now is a good charger...
Hard to decide..
Thx gyus...
Yes, but those numbers are probably inflated.
Ohh.. really?.. i thought HRB is a good choise.. bummer.
Not saying its not a good choice or not a good brand, just saying battery companies usually inflate their C ratings to look better than the next, most do it.
I don't know of any company posting honest numbers on C-rating outputs.
Most output a real 25-50c
There is only one battery I know of that has ever output more than 50c
