I was wonderings if the 3s and 4s shocks can be saved specilly the 4s shocks i know some people had leaking issues on them but could just a 4$ for a few sets of orings fix the leakage for ever?. The 3s shocks has a 3mm shaft and comes wih rubber seals 3x2mm the fix would be to try 2.8x1.9 would be the closest i think. And the 4s shocks uses 4x2mm for a 4mm shaft. The arrma 6s ones uses 3.8x1.9mm. As you can see the seals of the 3s and 4s shocks have the same diameter than the shaft and i think thats why they leak. So im asking if someone can do this experiment and just switch the o rings for silicones ones and see if they hold up. For anyone trying thank you
