Wouldn’t that mean you’d be dealing with constant bent turnbuckles? You need some form of “slop” in there otherwise it wouldn’t absorb nearly as much or as well.It's amazing the stresses these things have to deal with and aren't broken more often, mostly thanks to things like the servo saver and weak points to help prevent breakage on more expensive parts.
Think about it like this, a Kraton 6s is about 14ish pounds with batteries and inf you land on a wheel from 20 feet up it's going to experience hundreds of pounds of force in a fraction of a second which is why modern plastics are so amazing too...the engineering in these models is awesome especially for the price though I'd like to see a servo saver that has zero slop and still save a servo
Depending on the saver you have, you may not be able to adjust it. The older V3 and back savers had a screw type, which you could tighten or loosen depending on how much "precision" you wanted in your steering. Tighter meant less slop but more risk in damaging the servo or other steering parts. Loosen it up, and your steering feels less precise, but your components are better safeguarded. On the newer V4 saver, adjustment is possible, but very difficult. Seems like Arrma decided how tight is tight enough, probably to help reduce warranty claims for damaged servos and mangled steering parts. Hope this answers your question.I don't understand what a servo saver is. How is it adjusted to "save" your servo?
No because most of the materials on our vehicles can handle it to an extent and some (like shock ends) are a designed point of weakness. Better to break a rod end than a diff or shockWouldn’t that mean you’d be dealing with constant bent turnbuckles? You need some form of “slop” in there otherwise it wouldn’t absorb nearly as much or as well.
Eliminate one “weak point” create another.... haha
Silly engineers... RC cars don’t need servo savers! We’re onto something here! ..... ??No because most of the materials on our vehicles can handle it to an extent and some (like shock ends) are a designed point of weakness. Better to break a rod end than a diff or shock
There doesn't have to be slop, it's just a side effect of the materials and scale of the vehicle. Think of your full sized car, do you have slop there? Even on Baja trucks, no slop is a must. It's just much harder to avoid in a smaller package and the servo's don't have our arms to absorb the shock like full sized vehicles do.
That said, it is the reason we have breakages at all but the way things are designed and the materials used can deal with some of that stress by flexing and transferring the load down the line but everything has it's limits
My bad bro.....I didn’t see the video, apologies in advance....If my video didn’t explain what a servo saver is I’m at a loss ??
The video did a real good job of showing how to fix the loose saver of a Kraton V4 with it's "never loos" servo saver but not really the theory behind the servo saver in general.If my video didn’t explain what a servo saver is I’m at a loss ??
A servo saver flexes from bumps in the road that turn the wheels. So if you're turning right, the servo is trying to turn you right, but if a bump sends the wheels left, without a servo saver, the servo would take all that stress and you could strip your servo gears. By flexing and letting the wheels move a little without moving the servo gears, the servo saver "saves" your servo. Tightening the servo saver will keep your wheels on the line you want better, but will stress the servo more. Loosening the servo will spare your servo from stress, but will loosen up the steering precision. If you run on on smooth terrain and you want tighter steering response, you can tighten the servo saver. If you run on rough terrain, setting the servo saver too tight may end up damaging the servo.I don't understand what a servo saver is. How is it adjusted to "save" your servo?
Funny, thought I covered his question pretty wellA lot of answers here but I don’t think the OP question was answered. What’s the concept?
