Ok, first remove the back of the diff housing, 4 screws, and remove the entire diff assembly, check for shot bearings
From what I could see. The Axle wobbles in the bearing. Are there shims suppose to go besode the bering ?Ok, first remove the back of the diff housing, 4 screws, and remove the entire diff assembly, check for shot bearings
Ok I pulled it all apart lastnight. And there are no shimes at all on the bearing side or on top of the 0ring where the cross pin goes so I'm assuming I need a shim kitWith the diff removed from the housing, do the outdrive cups have the same slop (movement perpendicular to the axis)? If yes, then its either your bearings are gone or something is not right with your diff gears/case.
If not, check if there is play along the input gear, ensure that the outdrive cup is seated firmly against the bearing.
Shim the diff assembly (not gears). There is a post about that somewhere in here
The diff cup has a brass bushing that the axle goes through it seems as thou its worn outhttps://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/392123030511
I've been using this shim kit. It has worked great. Good luck
