Rip King MC
I was thinking about someday getting a BRCC and giving it some 6S electronics, but first, I want to know if the drivetrain can hande the power. Does anyone know?
Answer is simply NO..a big fat one ..if you upgrade those 2 things to 6s then you better also upgrade everything else.or you'll chew up everything.your diffs will get striped and your slipper clutch assembly will be toast.oh and you'll have a dead rockI was thinking about someday getting a BRCC and giving it some 6S electronics, but first, I want to know if the drivetrain can hande the power. Does anyone know?
Drive train should be upgraded to Handel the crazy 6s power.i can see you going from 3s to 4s but not 6 that's a whole different ball game. Just buy a 6s truck.if not then proceed with your dream and destroy your big rock .Answer is simply NO..a big fat one ..if you upgrade those 2 things to 6s then you better also upgrade everything else.or you'll chew up everything.your diffs will get striped and your slipper clutch assembly will be toast.oh and you'll have a dead rock
Again answer is NO lol .you just said it in a nice way . everyone gets trigger happyIf you are very gentle with your throttle finger, you might be able to keep the diffs or driveshafts or slipper together for a while. But ultimately it's going to reduce service life for all of those components unless you're able to pretty closely replicate 3s amount of power by limiting how far down you pull the trigger. Which sounds like alot of being very careful just to have power that you can't really fully use.
Anyone with a 6s will not be gentle on the throttle.lol that's like having a 600hp motor in your car but only do 60 on the highway..if you got the power use it..and fact is as soon as he drops that esc and motor in he will be trigger happy untill his diffs .bearings slipper clutch and center drive axel goes .and the sweet smell of burned plastic lol kiss your dead rock good bye.sorry to burst your dream .If you are very gentle with your throttle finger, you might be able to keep the diffs or driveshafts or slipper together for a while. But ultimately it's going to reduce service life for all of those components unless you're able to pretty closely replicate 3s amount of power by limiting how far down you pull the trigger. Which sounds like alot of being very careful just to have power that you can't really fully use.
I mean, technically OP is free to install whatever electronics desired in their truck.Again answer is NO lol .you just said it in a nice way . everyone gets trigger happy
