Can this fit on BRCC 3s
I had this same issue with my Ecx Ruckus, most EMaxx bodies were long enough but they are too wide.
So if I put the hot racing 10mm offset 17mm hubs I should be good to get this body??
The wheelbase is really close, but overall it’s shorter. You may have to modify for the bumpers? Can’t say for certain.
I was looking at the specs and it’s about an inch or so longer than my stock body, and I’m planning on getting the t bone racing bumpers which I’m pretty sure give my body a little more space.?‍♂️
Traxxas Slash bodies are basically a direct fit, might need to trim the wheel wells a bit though.
The black and green baja bug is my Ecx Ruckus.
That body is a decent bit longer than the stock body but idk
a direct fit to the BRCC right?? If so that makes life so easy
I also forgot with that bug body you will probably have to cut off the motor part of the body.
The BRCC uses the same chassis as the Senton, the Senton is basically the same size as the Slash. You might want the body mounts from the Senton as well.
Okay so a slash body would fit on the BRCC with senton body mounts? And would the truck look more like a truggy or something like that?
I would think so, you might have to trim the rear fenders so the tires don't rub, or you could run hub extenders as well. You might even be able to get it to work with the stock BRCC mounts.
LIT!! Imma go add that to the Christmas list real quick? and I had plans on running new tires and using the hot racing hub extenders so that’s not a big deal
And on the body mounts, I’m not good at doing the holes and I also find them ugly so I’m going to run some of these...
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/223187362639
or would they be too weak to run at those speeds? Keep in mind I’m only using this body and these magnets for driving up and down my road and not flipping over very much.
Those would constantly fall off every time you hit a bump.
