Taeboogie937
- Talion
Could you use a different spur gear for you front or rear diff ???
thank you for that I'm about to look on Ebay nowIf you can find them, you could swap in the straight cut 13/43 from the Typhon/Senton. But then you will also need a smaller pinion to keep the same overall gear ratio.
If you do the swap, you will need both the diff pinion and ring gear. Also, you will want to do both the front and rear, otherwise your center diff will hate you.
I'm about to look into it now thank you so much ..Found a seller on amazon https://www.amazon.com/gp/aw/d/B00N...=8-1&pi=AC_SX236_SY340_QL65&keywords=ar310497
