Can't figure it out
DetroitSS
Michigan
  1. BigRock 4x4
  2. Infraction
  3. Limitless
  4. Typhon 3s
No matter what I do my Castle mamba xlx2 just wont log any data. Does anyone know if there is some thing you have to do to get it to log, thx.
You have to select in the Castle link what data you want logged. It will be under logging and to the left you'll need to check what categories you want it to logđź‘Ť
I know I played around in there for some time. By default they were all checked. I checked, unchecked, checked again, Maybe a bum esc.
There's also a setting where it clears data every time it's powered on. If you have that set, then you can't power on the esc after you run it, you have to download the data without a power up, then you can power it on when done. I think that's the setting I use so I always end up with the last pack of the day in the logs on my MMX.
