I can't get the screws out of any of the aluminum(motor mount) on the Kraton. Why are they torqued so tight from factory? I've twisted a allen wrench and stripped screws. Any ideas how to get them out. Going to have to pull the dremel out I guess.
Just had same nightmare with new Kraton. You need hot soldering iron to weaken thread locker, if you have a Torx bit, hammer one into the stripped screw and attempt to torque out slowly with socket wrench using 1/4 attachment to Torx. Has to be very hot to weaken locker.I can't get the screws out of any of the aluminum(motor mount) on the Kraton. Why are they torqued so tight from factory? I've twisted a allen wrench and stripped screws. Any ideas how to get them out. Going to have to pull the dremel out I guess.
So they have thread lock on them? If so that explains why they are so tight. I'll pull the iron out soon and see if I can get them broken free. Didn't think of that. Whats the best way to replace the stripped screws? There a part number or something for the motor mount screw? Thanks
Dude.... This is the Arrma hang up, they over thread lock motor mount screws and pinion. If you bought at LHS, have them help you. If bought online see YouTube for ideas, this is my 4th Arrma, great rigs, but assemblers are overthread-locking. Heat and lots of it is a must. All screws into metal should expect locker on it. Don't strip further if not totally rounded already. I have to pass out, don't bust out the drill or Dremel, wait for a better solution. I drilled through one as a last resort, total PITA, effectively ruined a brand new motor mount. I'll check with you tomorrow.So they have thread lock on them? If so that explains why they are so tight. I'll pull the iron out soon and see if I can get them broken free. Didn't think of that. Whats the best way to replace the stripped screws? There a part number or something for the motor mount screw? Thanks
Hi,
I had the same problem. Arrma uses a lot of red loctite which is almost superglue. I don't understand why they are not using the blue one, that is perfect for rc's.
The only way to unlock screws with red loctite is a lot of heat. Use a torch if you have one!
If you stripped out the heads already and the iron won't work.....just drill the top of the heads completly off. This way you won't damage or cut into the chassis. Then just remove the motor mount. (put it in a vice) Once that is out...get a small drill and drill right down into the screws to hollow them out. (use fresh sharp drills) Once the screw wall is pretty thin...you can reverse a slightly larger drill bit on top of it and it should back right out. I replaced those motor mount screws with stainless Philips heads. No thread locker. They stay in there fine.
The blue can be a problem also...it sometimes causes the steel screw to react with the aluminum and just binds the threads up. Then you go to remove it with a worn out Allen wrench on a low quality screw and it's all over.
Almost bought one after last motor mount nightmare, which brand do you use and how long is torch applied? I was worried I'd melt surrounding plastics, diff case...etc.I keep a small propane torch readily available, works good for removing small 3/4mm bullets from wires also.
Thanks, I'm getting one next trip to HD.It's the standard blue tank, hand held quick lite. I ussally just turn it all the way down.
