When I first I got my rc I was a rookie. My wheel came off, I searched what was the problem and I found out it was a common issue. So dumb me red threalocked both the wheel driveshafts and diff driveshafts now I can't open my diff any ideas?
Note: This feature currently requires accessing the site using the built-in Safari browser.
cut off the drive shafts to expose the screw and carefully heat it, so you can at least save the diffs.
As I said I had just gotten my truck. I didn't know how to work on rc cars.Also have a senton. You probably know this by now but no reason to use red anywhere on this truck. Only use blue in metal to metal connections.
Rest in peace wallet..Your won't be able to heat those screws without melting through the plastic. Best bet is just order a couple diffs and driveshafts from Jennys. You Might be able to cut off the drive shafts to expose the screw and carefully heat it, so you can at least save the diffs.
The driveshafts that are screwed on the diffs yes.You used red Loctite on your diff screws?
