Pushing the trigger up/forward it goes forward.. when pulling the trigger nothing happensWhy are you trying to bind? Should have been bound from the factory if your using the Tx it came with.
Also if your trying to go backwards AFTER going forwards and braking, you need to go full brakes first and then neutral and then it will move backwards when moving the trigger to reverse.
Okay thanks my controller settings was way offPage 23 in manual...all of your settings match? Unless you use your throttle opposite/ reversed. Only other thing is check throttle trim, but make sure you have the car off the ground when setting it.
